Electrical
NISSAN SENTRA
SPYGA03
Hi, my nissan sentra 2000, 116,000 miles is driving me crazy. Whenever i drive it for more then 30 min, my brake and battery light comes on. I recently had my car tuned and they told me that my battery and brakes are fine. I have had problems with my tail lights in the past not turning on, and my interior light aroung my gear does not work. I am thinking its electrical, but would like to make sure.
Thank you
Apr 25, 2006 at 12:14 AM
LOSONE
  • 1,616 POSTS
Hummm I think you need to have the alternator checked. If it isn't working right it will cause the battery light to come on. Let me know
Apr 25, 2006 at 11:27 AM
ERNIE ERKMAN
there is a short in the system probably under the passenger front seat this is where the junction block that ties the front electrical to the rear electrical. its a grounding problem. do you blow taillights? [email protected]
May 25, 2006 at 6:54 PM
S0CRAZYRIGHTN0W
That problem could simple. If your car is a manual, there is a screw underneath your e-brake. If the metal from the brake is coming in contact with the screw, the light will come on. If not, it probably just means you need to get the breaks changed. On certain vehicles, the brake light will come on when they need changed. These possibilities are more probable then an electrical malfunction.
May 25, 2006 at 8:18 PM
