Hi!
I replaced my fuel pump. after I replaced it the check engine light came on the codes that it showed were PO181 and PO183. So, I called up the Nissan dealership and talked to the repair guys there. They said it can only be a bad pump and I should replace it again. So I did. As soon as, I replaced the pump the same codes keep coming up. So I don't think it's the pump. So my question is. Is there something else I need to replace when replacing the fuel pump?
Thank you!
Thank you!
Sep 23, 2010 at 11:31 AM
