my nissan sentra is vibrating when i go around 65 + mph and the car also shakes when i apply the brakes at 65+ it will make some annoying sound from the brakes more like brake grinding noise
this started happening after i got my front brakes done changed the rotors and brake pads, i also got the tires in the front changed to 2 spare tire and got the balancing and Wheel Alignment, brake fluid flush and power steering flush.
i took it back to the shop i got this done he told me the sound is because the brakes are new. n the vibration is because the tires are used n one of them is uneven.
so i took the car to another shop n they told me maybe its the balancing so they did the balancing n i told them to check all the wheels n see if is it beacause of the tires the vibrations is coming n they said the tires are fine.
Any suggestions would be most helpful...
thank you
thank you
Mar 19, 2010 at 10:37 AM
