2005 Nissan Sentra Gas Tank
2005 NISSAN SENTRA
75,877 MILES • 4 CYL • FWD • AUTOMATIC
SMITH5549
Hi - thanks for the website!
All of a sudden when I tried to put gas in my car it squirted back out - no it wasn't full....
I can only put in a little at a time, currently at 2.41/gal, I can put in about 50-70 cents at a time, then I have to stop and wait a few seconds and then put in anoth 50-70 cents worth. I don't want to bring it to a dealer without having an idea of what it may be, for obvious reasons. I would greatly appreciate your help.
Thanks
Billie
Oct 27, 2008 at 3:24 PM
IMPALASS
  • 3,112 POSTS
Hello Billie - sorry to hear your vehicle is not acting right. First and most important - you have two recalls on the fuel tank. This could cause a fire. Please call the dealer as soon as you can and they can check by your VIN number if the recalls have been taken care of. The first recall talks about the vapor hose. In the pic I have attached I belive it is called a vent hose. This may be your problem. If the vent hose is kinked, clogged or blocked what you are describing is possible of happening. Here are the numbers of the recalls. The first Recall Reference: NTB05-060 Date: August 12, 2005 VOLUNTARY RECALL CAMPAIGN SENTRA FUEL TANK VAPOR HOSE CAMPAIGN I.D. # / NHTSA #: PM501 / 05V-269 APPLIED VEHICLE: 2005 Sentra (B15) APPLIED VINs: Vehicles built between: 3N1*B51**5L487119 - 541526 The Second Recall MAKE/MODELS: MODEL/BUILD YEARS: Nissan/Sentra 2005 MANUFACTURER: Nissan North America, Inc. NHTSA CAMPAIGN ID NUMBER: 05V269000 RECALL DATE: June 03, 2005 COMPONENT: Fuel System, Gasoline: Storage POTENTIAL NUMBER OF UNITS AFFECTED: 44000 SUMMARY: On certain passenger vehicles, a vapor hose located in the fuel tank may not have been formed correctly during the manufacturing process. When the vehicle is parked with a full fuel tank, fuel may flow into the vapor hose, which is connected to a vapor canister. CONSEQUENCE: The vapor canister could become full, and excess fuel could spill out onto the ground. Fuel leakage, in the presence of an ignition source, could result in a fire. I would also check the filler neck where the hose goes into the fuel tank for any kinks, anything logged etc. My first thought though is a bad vent hose.
https://www.2carpros.com/forum/automotive_pictures/248015_Fuel_Tank_1.gif
Oct 27, 2008 at 8:42 PM
SMITH5549
Thanks for the quick response.
Oct 28, 2008 at 12:12 PM
