2005 Nissan Sentra Engine revving itself
2005 NISSAN SENTRA
70,000 MILES • 4 CYL • FWD • AUTOMATIC
GDMATTINGLY
Check engine light came on, the diagnostic reading showed a code for stuck or sticking throttle plate. Cleaned throttle body w/ throttle body cleaner, not engine is idling higher, & once warmed up will rev itself between 1500-2000 rpm. Any ideas?
Apr 6, 2010 at 11:59 AM
Check and test the MAF and TPS sensors to include vacuum leaks
Apr 6, 2010 at 12:29 PM
FLASH728
  • 12 POSTS
Mine does the same thing currently, if you still have the car, what did you do to fix it?
Aug 8, 2012 at 4:40 AM
