2004 Nissan Sentra Rear Drum Brakes
2004 NISSAN SENTRA
148,000 MILES • 4 CYL • FWD • AUTOMATIC
UBRDEM
  • 5 POSTS
I need some help with the Rear Drum Brakes.
First of all, my brother and I were attempting to get the drum off, which proved difficult. After reading a Haynes Manual, which seemed to describe the process in kind of backwards way from what it actually was, we figured out we had to release tension on the shoes with the adjuster star nut/ring.
While attempting this, however, we soon discovered that we were actually expanding the adjuster, which made removal of the drum impossible. We cannot get the adjuster ring to move in the opposite direction, and the brakes are now seemingly locked into an engaged position on the drum while driving.
So far we attempted to remove the bearing in an attempt to break it free via wiggling the rim back and forth, but the whole assembly appears different from what one would expect. There is no cotter pin. Just a large, I assume 30mm, 'nut' that has been crimped onto some shaft.
What can we do???
Jul 18, 2009 at 7:20 PM
MHPAUTOS
  • 31,937 POSTS
HI there,
Try and have a look in the adjuster slot with a torch, the adjuster wheel has a plate that stops it from backing off in normal operation, to un adjust the brakes you have to push his plate with a screw driver back(toward the drum) and the adjuster will now turn in either direction , back the brake s off and remove the drum.
mark (mhpautos)
Mar 13, 2021 at 6:42 PM
