Engine scan after check engine light came on indicated faulty oxygen sensor.Scan does not specify which sensor is bad so i replaced both sensors with aftermarket brand name sensors.After clearing code , code came back. I was told only original equipment oxygen sensors will work on this car because the wire splice prevents proper operation. Do I now have to buy Nissan oxygen sensors? The wire color codes are correct as per instructions and the splices are good.
Dec 22, 2009 at 8:33 AM
