2003 Nissan Sentra Hard to start
2003 NISSAN SENTRA
MACK920
Engine Performance problem
2003 Nissan Sentra 4 cyl Front Wheel Drive Automatic
Why does the engine fail to start right away after it reaches operating temp. Starts fine when I start it first thing in the morning, but once I drive it for 15 mins. and turn it off for 10 mins it will start only after 2-3 tries. Engine turns fine acts like its not got any fuel. I can hear the pump running . Engine runs fine otherwise.
Mar 24, 2009 at 4:08 PM
Check your fuel pressure make sure its within specification and also the engine coolant temperature sensor.
Mar 24, 2009 at 4:32 PM
MACK920
[quote="Mack920"]Engine Performance problem
I did change the coolant temp sensor a couple weeks ago. I will check the fuel pressure next.
Thanks !!!
Mar 25, 2009 at 7:14 AM
MACK920
[quote="Mack920"][quote="Mack920"]Engine Performance problem
rasmataz, I checked my fuel pressure and it has 52psi when the engine is runing. Turn the engine off and it drops too 0 psi within 15 seconds. Could it be a leak inside the tank or the regulator not holding the pressure, no leaks outside the tank. I would really appreciate your advice !!!!!!
Apr 3, 2009 at 4:25 PM
