2003 Nissan Sentra Engine Noise
2003 NISSAN SENTRA
86,680 MILES • 4 CYL • 2WD • MANUAL
ZELEANON
The car has done this for some time now, without any effect on performance as far as I can tell. I got the car with 64000 miles on it from an older lady.
When you start it and it's cold, it'll make a "clicky noise" sounds kind of like the ticking of a sewing machine. Up a few hundred rpms and it'll tick faster. But when driving it is not noticeable, or if you rev past a few hundred it quits. Does when warm too, but probably less noticeable. Any ideas?
Jan 8, 2010 at 12:15 PM
DOCFIXIT
  • 18,828 POSTS
Lifter clatter have valves been adjusted on regular bases?
Jan 8, 2010 at 1:52 PM
ZELEANON
I don't think they've ever been adjusted in 86000 miles. Older lady said they were "nonadjustable" and I just kinda took that at face value...
Jan 8, 2010 at 5:57 PM
DOCFIXIT
  • 18,828 POSTS
Might want to have valves adjusted. If engine is 1.8L then adjustable what model Sentra?
Jan 9, 2010 at 1:39 PM
ZELEANON
It's a Sentra XE, base model with standard transmission and manual everything.
Jan 12, 2010 at 8:33 PM
DOCFIXIT
  • 18,828 POSTS
Then adjustable the rub is they are adj by shims will need to find a shop with shim assortment
Jan 14, 2010 at 8:35 AM
