Manifold absolute pressure sensor
2001 NISSAN SENTRA
MICHAELG66
Four cylinder two wheel drive automatic 123,500 miles.
I just recently purchased this car it is the GXE model with a 1.8 engine.
I was told to replace map sensor I purchased part with the intention of doing the job myself unfortunately I have no idea of the location of the manifold absolute pressure sensor. can you answer this? where is the map sensor located on my car? please keep in mind it is a California engine which I realized when I was trying to find location of map sensor. I live in New York City different emissions standards. I do not know if that matters. all I am sure of it has decreased car performance and gas mileage.
Feb 26, 2010 at 7:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The manifold absolute pressure (MAP) sensor for the 1.8L California engine is located on the right side of the firewall, pictured below.
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed. Cheers
Feb 26, 2010 at 9:40 PM
ERIKSSEDAN
Four cylinder front wheel drive automatic.
How can I fix a MAF sensor or is it fixable?
Sep 6, 2018 at 3:04 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
You can try cleaning it, but if it does not help then the sensor will need replaced. You can follow the link below to watch how to clean a MAF sensor. The video shows a FJ cruiser but the cleaning procedures are the same.
http://www.youtube.com/watch?v=qiEdey2IHcc
DAVID692
Having a problem with the mass air flow or the volume air flow.
What is the problem with the MAF? Do you have a code for it?
HAWKYEAH
The idle is rough on it at low idle especially in drive while foot is on the brake. I was told its the mass air flow sensor. I was wondering if a mass air flow sensor just from your local Napa will work or if you need a updated one from the dealer? And also does it have to do a idle relearn?
Inspect wiring to it and clean it with an approved cleaner and see what happens.
