2000 Nissan Sentra Engine Miss fire
2000 NISSAN SENTRA
80,000 MILES • 4 CYL • FWD • MANUAL
BORMANT
Only miss fir4e when starting from a dead stop only for a few soconds
Mar 26, 2010 at 10:47 AM
Engine running rough or misfiring can be cause by the following-inspect and test all the following below:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Mar 26, 2010 at 5:41 PM
