1998 Nissan Sentra Distributor
1998 NISSAN SENTRA
11,700 MILES • 4 CYL • FWD • AUTOMATIC
JMATHERSON
The distributor is giving off a very weak spark and the car won't start. What could be causing this?
Dec 31, 2008 at 8:22 PM
ZACKMAN
  • 4,202 POSTS
Remove the 2-wire connector from the distributor housing. Check resistance between those two wires (primary resistance). It should be about 1.0 ohm.
Test secondary resistance between black/wire wire on the connector and the high tension tower (on the distributor towards the cap. It should be about 10,000 ohms.
If either one is not within specs, replace distributor as a unit.
Jan 5, 2009 at 1:13 AM
