1997 Nissan Sentra overflow drain
1997 NISSAN SENTRA
170,000 MILES • 4 CYL • FWD • AUTOMATIC
TAUB4126
how do i clear a overflow drain, it leak's water all over the passenger floor when ac is on. i tried to pull blower box out from behind glove box but it hanges up under dash with what i can see all mounting screws and bolts out. i dont want to take out upper dash out too. i put up on ramps and went under car to see if there was blockage at the tube on firewall and it seems clear. what can i do to fix this problem.
Jul 13, 2008 at 11:09 AM
KHLOW2008
  • 41,814 POSTS
Hi taub4126,
The drain hole on which the tube is attached might be clogged. Did you try to clear it by pushing a wire through it?
From under dash, at lowest point of evaporator, check if the tube is kinked.
Jul 19, 2008 at 12:59 PM
