1997 Nissan Sentra Blown head gasket
1997 NISSAN SENTRA
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
BRECK218
Will a blown head gasket keep this car from cranking or running and if so, how much should it cost to repair?
Jan 30, 2008 at 8:31 PM
BLACKOP555
  • 10,386 POSTS
a blown head gasket wont cause the vehicle to crank, a bad intake manifold gasket could if you have a wet type manifold.
but a blown headgasket would prevent a car from running right or even running, perform a compression test on each cylinder to find out, lowest should be no more then 25% less then the highest cylinder.
Jan 30, 2008 at 8:39 PM
[quote:606721be76="breck218"]Engine problem
1997 Nissan Sentra 4 cyl Two Wheel Drive Automatic 90,000 miles
Will a blown head gasket keep this car from cranking or running and if so, how much should it cost to repair?[/quote:606721be76]
Check the cylinders for coolant if its a headgasket it will show in this model sentra-BTDT and don't forget to have the head resurface.
Jan 30, 2008 at 9:08 PM
