1995 Nissan Sentra Clearance and Tail lights don't work
1995 NISSAN SENTRA
SOLOSENTRA
My tail lights and my clearance lights don't work...but the headlamps and the turn signals are working.
I tried installing a window washer light...and I connected the wires to the wires of the turn signal/ clearance light power as I was instructed. After that, the clearance lights and the tail lights stopped working.
I can assume its a fuse...because the person who installed my new starter didn't connect the ground wire...but the ground wire is just touching the bolt on the started where it should be bolted, but it is not bolted on...help me out.
Feb 23, 2007 at 11:52 PM
check the tail lite relay if it has one-also a disconnected wiring connector for the lites and ground system
Feb 24, 2007 at 4:27 AM
