1994 Nissan Sentra where is the computer
1994 NISSAN SENTRA
256,000 MILES • 4 CYL • 2WD • AUTOMATIC
MOOSECHOLOK
  • 4 POSTS
I have a check engine light and cannot find the computer? How do I read the codes from the computer?
May 6, 2010 at 9:23 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the data link connector is what you are looking for and it is under the left side of the dash, below the fuse block.
May 6, 2010 at 10:45 PM
MOOSECHOLOK
  • 4 POSTS
Okay, I found the data connector, now how do i retrieve the codes? Thanks!
May 7, 2010 at 6:38 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2126.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_688.jpg
May 7, 2010 at 9:16 AM
MOOSECHOLOK
  • 4 POSTS
first you said the connector was in the fuse box and I found that. How do you access the codes through the connector and if you cannot, where is the computer with the LED lights?
Bill
May 7, 2010 at 10:02 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you need a Nissan Consult Tester (J-38465) to use with the DLC. just plug it in the DLC. without scanner, you can use the LED system. the ECM is located under the center of dash
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_492.jpg
May 7, 2010 at 11:06 AM
MOOSECHOLOK
  • 4 POSTS
Thanks. Now, will I see the LED if I take apart the console? Bill
May 7, 2010 at 4:47 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes the LED light is on the ECM itself, so once the console is removed you will have access to the ECM and the light
May 7, 2010 at 5:20 PM
