1994 Nissan Sentra SPUTTERING
1994 NISSAN SENTRA
191,000 MILES • 4 CYL • FWD • MANUAL
NOEL6783
MY CAR IS SPUTTERING DURING NORMAL ACCELERATION BUT IF I BARELY TOUCH THE ACCELERATOR RPMS GO UP FINE BUT IF I HIT IT LIKE IM GONNA TAKE OFF FROM A LIGHT IT STARTS SPUTTERING SO BAD THAT I HAVE NO POWER AND DOESNT WANT TO GO. IVE GOT NEW CAP ROTOR WIRE PLUGS AND FUEL FILTER ALSO HAVE A SHORT RAM INTKE ON IT. ANY SUGGESTIONS WOULD BE GREAT.
Sep 22, 2008 at 9:45 PM
ZACKMAN
  • 4,202 POSTS
Check your timing. Make sure that it is correct at 6 - 8 BTDC. If you have the SE-R, then it is 13 - 17 BTDC.
Then check/clean you TPS sensor.
Aug 2, 2018 at 6:36 PM
NOEL6783
thanks for the info i checked all that and found that the proformance coil that i installed went bad i hooked my stock coil up and holy cow it worked i was not happy that i spent 4 days tryin to figure out what the problem was but that was it. thanks
