1994 Nissan Sentra sentra no pulse at injectors
1994 NISSAN SENTRA
TALSTERCA2000
Electrical problem
1994 Nissan Sentra 4 cyl Two Wheel Drive Automatic
hello
04 sentra 1.6L i replaced the fuel pump, i have a strong spark, my problem is that i have no pulses in the injectors?? is there a comun problem to the sentra like corrosion at the computer or cranck sensor ? need help what to check next please...thank you in advance
Dec 23, 2008 at 2:29 PM
ZACKMAN
  • 4,202 POSTS
I can't say if this is a common problem to GA16. You computer is under the dash, so corrosion is unlikely. Crankshaft position sensor is used by the ECM only to detect engine misfire.
According to FSM, if injector pulse is not within specs, check:
1. Harness and connector
2. Injector
3. Mass air flow sensor
4. Intake air system
Dec 24, 2008 at 1:05 AM
