Two weeks ago I noticed that the brake lights on my 1994 Nissan Sentra XE were on, even though the car was off and the key removed from the ignition; I also found pieces of black rubber on the driver-side floor. I learned that the pieces were in fact the brake pedal stopper and so I bought a replacement stopper from a Nissan dealer. I installed the replacement stopper (which is now a clear rubber) and thought the problem was solved until today, when I noticed yet another black stopper in pieces on the driver-side floor. The car is working fine but I am anxious to know exactly where this particular stopper (which is identical in size to the one that I replaced at the brake switch) is from. Can you help with some advice? Much thanks.
May 31, 2010 at 8:09 PM
