1994 Nissan Sentra battery light is on
1994 NISSAN SENTRA
209,450 MILES • 4 CYL • FWD • AUTOMATIC
MARCOS17
  • 4 POSTS
i just bought a nissan sentra xe, and the battery light is on, e brake, and the wiper light is also on too. the battery light i believe it could be the alternator but im want to make sure before i go buy it. there is also a sound every time i go on a bump like if the it only had springs.. what do you think those problems could be ???
Apr 25, 2008 at 8:26 AM
DISCOSTU24000
  • 37 POSTS
you'll need a voltmeter to test the battery and alternator. Read this tutorial on how to test these parts: https://www.2carpros.com/how_to/test_alternator.htm
The wiper light probably just means you're low on washer fluid.
The suspension issue could be a variety of things, bad shocks, bad springs, etc. You would need to do some inspection of these parts to get a better idea
Apr 25, 2008 at 3:41 PM
MARCOS17
  • 4 POSTS
[quote:f8c8d24f98="discostu24000"]you'll need a voltmeter to test the battery and alternator. Read this tutorial on how to test these parts: https://www.2carpros.com/how_to/test_alternator.htm
The suspension issue could be a variety of things, bad shocks, bad springs, etc. You would need to do some inspection of these parts to get a better idea[/quote:f8c8d24f98]
i check the suspension today, i lifted the car and shake the tire from right to left and up and down to see if the ball joints were the alright.... when i shaked the tire from right to left i heard i clicking noise i...... could it be the sway link???
Apr 26, 2008 at 9:29 PM
