1993 Nissan Sentra no continuity from ground to throttle po
1993 NISSAN SENTRA
104,000 MILES • 4 CYL • 2WD • MANUAL
GERALD A. WATANABE
i had a problem on my electrical connector from tps pin(gray wire) to chassis gound thats why my throttle possition sensor is not functioning i already compare it to other same car and it has continuity form tps pin to ground...
Nov 25, 2008 at 11:55 PM
Find the open wire between the TPS and ECM or splice in and take it to a ground point
Nov 26, 2008 at 12:04 AM
GERALD A. WATANABE
[quote:f423b73d7b="rasmataz"]Find the open wire between the TPS and ECM or splice in and take it to a ground point[/quote:f423b73d7b]i already did that but problem is when the reach its normal temperature the car stalls and it will never starts again until i cut off the ground wire.
Nov 26, 2008 at 12:16 AM
Okay I want you to unplug the engine temperature sensor and the exhaust gas sensor and tell me what happened-that gray wire goes to this 2 components-could be grounded that side-
Nov 26, 2008 at 12:32 AM
