1992 Nissan Sentra engine lurches at low throttle in overdr
1992 NISSAN SENTRA
200,000 MILES • 4 CYL • FWD • AUTOMATIC
EVOCHICO
Have been "shade tree" mechanic on trucks-cars & motorcycles many years yet am about stumped. On '92 Nissan GA16DE replaced injectors, fuel filter, checked connectors, R&R vacuum hoses, R&R plugs & wires, new MAF, cleaned distributor & cap & rpld rotor, can of SeaFoam thru booster vacuum hose, cleaned throttle body, injectr cleaner in tank, premium fuel in tank, no trouble codes in ECU- engine always starts & is reliable yet begins to lurch at even throttle cruising speed after shift to overdrive or high gear if overdrive is turned off. Gets worse/better some times but can not be attributed to weather/moisture. Suspect distributor. Thanks
Aug 20, 2010 at 7:46 AM
MHPAUTOS
  • 31,937 POSTS
HI there,
Thank you for the donation,
Have you checked the fuel pressure and fuel flow? often these surge problems are fuel delivery related, i would check these first and also ensure that the vacuum system is not leaking at all.
mark (mhpautos)
Aug 20, 2010 at 9:39 AM
