1991 Nissan Sentra Leaking fuel line
1991 NISSAN SENTRA
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
TENKIDZZ
My mechanic tightened the clamps on my fuel line but said if that doesn't work, it will require replacing it. Is this something a backyard mechanic can do safely? If so, how is it done?
Jul 9, 2008 at 3:26 PM
SERVICE WRITER
  • 9,123 POSTS
Depends on where it's leaking and how your going to route it and the material you use. You need to see where your going to be able to splice into, if there is areas that are stable enough to hold up.
Are you going to use high pressure fuel hose? or steel line with comprssion fittings?
Factors that can turn this into a nightmare are "what else will be disturbed while doing this? PRimarily brake lines. IF the lines are run close together, moving one line cause disturb another and cause another leak.
Can a BY mech do it? Depends on the one doing it.
Jul 10, 2008 at 5:07 AM
