1991 Nissan Sentra
1991 NISSAN SENTRA
YANIRA
1991 Nissan Sentra 4 cyl Automatic
I'm having trouble finding the right fuel lines to check on my 91 nissan sentra, is there a diagram somewhere anywhere I can look at before I decide to just drop the fuel tank. I'd rather not do that if it's unnecessary but I just cannot find the right lines.
Mar 27, 2010 at 2:44 PM
The line you're looking for is attached to the fuel filter located on the firewall near the brake master cylinder-you check fuel pressure there.
Mar 27, 2010 at 3:00 PM
YANIRA
Found it and followed it. We're looking for tears, it showed on the test we have a small leak. But none of the hard lines or soft lines seem to be in need of replacement.
I guess we're dropping the fuel tank anyway.
Mar 27, 2010 at 5:03 PM
it showed on the test we have a small leak. What is your pressure readings? You don't have to drop the fuel tank the access to it is thru the back seat to remove the fuel pump.
Mar 28, 2010 at 4:47 AM
