Remove all brake fluid from reservoir. Remove brake master cylinder from the booster, should be 2 nuts. From inside the car, remove the booster retaining nuts, I think there 3 of them. Remove the pin attaching the pushrod. Now you can remove the booster.
Make sure that you bleed your brake after you are done.
Mar 13, 2021 at 6:59 PM
