1988 Nissan Sentra airflow meter
1988 NISSAN SENTRA
V9L6N4
  • 12 POSTS
Electrical problem
1988 Nissan Sentra 4 cyl Front Wheel Drive Automatic low miles
I need the airflow wiring harness diagram to find the problem wire
Nov 5, 2008 at 9:40 PM
IMPALASS
  • 3,112 POSTS
Hello
Please let me know the specific vehicle you have since there are several Sentra’s to choose from. Is it a Sentra Hatchback Coupe, Sedan, Wagon, Wagon FWD and also the specific engine by Liter.
Last you question is a little unclear to me. I know you need a wiring diagram but I don’t understand the “airflow” wiring harness. Please be more specific on your request. There are numerous air sensors, valves etc – air injection valves, air induction, etc.
Nov 5, 2008 at 10:12 PM
V9L6N4
  • 12 POSTS
I need the wiring harness between the ECU and the airflow meter
Nov 5, 2008 at 11:12 PM
IMPALASS
  • 3,112 POSTS
Hello This is going to be hard to see - you may have to save it to your computer then open it in picture viewer - if that doesn't work then provide an email address and I will send it as a power point slide. Also, you did not specify your vehicle type and engine type as requested - so this is from just a Sentra.
https://www.2carpros.com/forum/automotive_pictures/248015_Graphic_3.jpg
Nov 6, 2008 at 8:01 PM
