1988 Nissan Sentra
1988 NISSAN SENTRA
MDC5659
1988 Nissan Sentra
trouble get spark to my plugs after replacing a head gasket. Not sure why this would be an issue after not ever having an issue with spark before head gasket problem.
Dec 13, 2008 at 9:17 AM
JAMES W.
  • 2,394 POSTS
I'm sure you already have, but re-check your wiring. Do you have plus voltage to the coil? Any blown fuses or pinched wires? Please advise.
Dec 13, 2008 at 2:49 PM
MDC5659
I do have voltage at the coil and I've check and rechecked the wiring. No blown fuses either.
Dec 13, 2008 at 6:33 PM
JAMES W.
  • 2,394 POSTS
With 12 volts to the plus side of the coil, either the coil is bad or the trigger in the distributor. Try grounding the - negative side of the coil with quick swipes and see if you get a spark.
Dec 13, 2008 at 10:41 PM
