Good morning.
picture attached below.
Procedure below.
Removal And Installation
Vehicle Engine, Cooling and Exhaust Engine Timing Components Timing Belt Service and Repair Procedures Removal And Installation
REMOVAL AND INSTALLATION
imageZoom/Print
imageZoom/Print
TIMING BELT REMOVAL
CAUTION:
- After removing timing belt, do not rotate crankshaft and camshaft separately because valves will hit piston heads.
- Do not bend or twist timing belt too tightly.
- Ensure timing belt, camshaft sprocket, crankshaft sprocket and belt tensioner are clean and free from oil or water.
- Before installing timing belt, confirm that No.1 cylinder is set at top dead center (T.D.C.) on compression stroke.
- Align arrow in direction of timing belt rotation.
- Adjust timing belt tension with all spark plugs removed.
1. Remove the following parts.
- Front right side splash cover
- Front right side under cover
imageZoom/Print
2. Remove the following belts.
- Power steering oil pump drive belt
- Compressor drive belt
- Alternator drive belt
imageZoom/Print
imageZoom/Print
3. Set No. 1 cylinder at top dead center (T.D.C.) on its compression stroke.
4. Remove the water pump pulley and crankshaft pulley.
NOTE: The crankshaft pulley is accessible after removing side cover from inside R.H. wheel house.
imageZoom/Print
5. Remove right side engine mounting bracket.
NOTE: Support engine by placing a jack under oil pan. Do not place jack under oil pan drain plug.
imageZoom/Print
6. Remove upper and lower dust covers. Use a torx wrench.
imageZoom/Print
7. Loosen timing belt tension lock nut and rotate tension clock- wise. Then tighten tensioner lock nut.
8. Mark rotating direction mark on timing belt and Remove timing belt.
CAUTION:
9. Remove belt tensioner and return spring.
10. Inspect the condition of belt tensioner and tensioner spring.
Jan 14, 2021 at 9:18 AM
(Merged)
