2004 Nissan Quest front wheel bounce when braking
2004 NISSAN QUEST
63,000 MILES • 6 CYL • 2WD • AUTOMATIC
MANZY ATCHISON
when braking or stopping hard the front tires bounce
Aug 28, 2009 at 8:10 PM
MERLIN2021
  • 17,250 POSTS
If more than the normal wheel hop of the ABS system, have the struts looked at! There is also a tech bulliten about the low tire pressure transmitters having a slow leak, so check tire pressure if you have this sytem! They replace the seals.
https://www.2carpros.com/forum/automotive_pictures/62217_quest_2.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_questb_1.jpg
If the trouble started after an alignment, it was done wrong. Bulliten states NOT to use the green and red lights on alignment machines! Use specs only.
Aug 28, 2009 at 8:16 PM
