2000 Nissan Quest CAR WILL NOT START UP
2000 NISSAN QUEST
DAVID152
2000 Nissan Quest Four Wheel Drive Automatic 80000 miles
HAVING PROBLEMS STARTING UP THE CAR WONT CATCH
Aug 23, 2010 at 10:47 AM
Cranks but no start condition-do below to determine whether it's fuel or spark issue:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Aug 23, 2010 at 10:19 PM
