1999 Nissan Quest Van overheats
1999 NISSAN QUEST
128,000 MILES • 6 CYL • FWD • AUTOMATIC
RAYDURSWIN12
My 1999 Nissan Quest was overheating so i took it to the mechanics and he said i need a new Radiator and Thermostat , so he replaced them both . 2 days later its still overheating so i took it back , he said you need a new water pump along with timing belt so he replaced them both then the next day its still overheating so i took it back and he said he had to replace the Thermostat Unit so he did , now 4 days later ! This morning i turn it on and there is a loud clicking sound but as soon as i drove away the sound is gone but i get on the freeway and it starts overheating again !! Does anyone know what it could be ? Thank you
Aug 10, 2009 at 2:19 PM
Fire the mechanic and go somehwere else and get it block and pressure tested if not an airlock to rule out a blown headgasket cracked head or block
Aug 10, 2009 at 2:31 PM
RAYDURSWIN12
Thank you for your response , so a assume a head gasket would cost me an arm and a leg ?
Aug 10, 2009 at 2:55 PM
