I have Nissan Quest mini van 1999, 100:000 miles .
I have problem with Radiator fan did not turn on low speed when engine warm . The fan turn on only on high speed , or A/c or heat on .
1) I tested the Fan by Jumped the hot wire directed from battery to the fan , It worked .
2) I tested all three relay . apply power to each invidual , all three clicked
03) I checked power of three terminal , all they have power , when inigtion key was on position .
The problem is there is 7.5 am RAD not power at all . Engine off , or run , the fuse checked ok . there is no power , even engine ran ,
The raw of Fan relay A is low speed , B is high 1 , C is high 2,
4) I switched relay by one at the time , both B and C high speed worked .
The problem is A relay position not work at all . runing engine to hot . But relay did not click to close curcuit , so the low speed can turn .
I moved same relay to the other place B and C high speed fan , it worked high speed fan .
The theomastart worked Ok , Coolant sensor worked , It send signal to turn high speed fan on .
Please , Tell me How do you think ? Thank yoiu
May 25, 2009 at 8:40 AM
