Brakes problem
1999 Nissan Quest 6 cyl Front Wheel Drive Automatic
Hi , I have Nissan Quest 1999 With no ABS , 116,000 miles , I have a trouble with brake did not hold pressor ,
First thing , I have the brake locked front left wheel . I replaced 2 new calipers , 2 set brake pad and service turned rotor for both side . Then I tried bleeding brake fluid 2 front brake , But it 's alway spongy .
2nd thing , I replaced 2 Master cilynder , the one 1999 model , It leacked at steal hose , I could not fixed , I switched to 2002 MC , It 's little bit difference , but with 2002 steal hose , It stop leak . and I also removed and clean 2 rear brake .
From here , I did bleeding brake fluid for four brake , untill there were any bubles in for brake , But the brake pedal till feel spongy , the 2 rear wheel you can moved by hand with the brake padel down.
First tried bleeding with engines off, after steped 10 times bring pressor on padel , It took slow to bring up the pressor to brake padel , After completed all for brake bleeding , I still feel some better , not very good , When engine runing brake spongy, I can depress brake to floor softly. 2 front brake some strong , but not 2 rear not hold the drum .
Do you think the 2 rear wheel cilynder did not spend the brake ? so the Brake shoes can hold the drum ?
I also checked Power brake booster ok , no airtighness , My Van is not ABS , 2 brake fluid line from MC to distributor block and 2 line out from there,
Do you think It could be MC again ? Because the pressor is not solid , and no any buble in brake line , I have been bleeding for all week long , 3 bottle 32 oz.
Some one tell me What could cause problem ? Please, Any helps will be appreciated ,
Jul 23, 2009 at 7:32 PM
