1994 Nissan Pulsar cooling system advice
1994 NISSAN PULSAR
76,000 MILES • 4 CYL • 4WD • MANUAL
MIKEY MATALO
hi. i have a pulsar GTI-R year 1994.
after driving her for bout 20-30min the coolant becomes excessively hot. it boils up and bubbles and causes the expansion tank to shake with the coolant spilling out of the overspill port in the bottle. however the temp gauge on the dash reads normal temp
iv noticed aswell that the cooling fans do not cut when the coolant gets to this high temp
Aug 18, 2010 at 10:35 AM
KHLOW2008
  • 41,814 POSTS
Hi mikey matalo,
Thank you for the donation.
Check the radiator cap. If the cap is bad, it would not be able to hold pressure and that would result in the bubbling at the recovery tank. Replace the radiator cap and test if the bubbling still occurs.
Check the coolant level in radiator and if it is low, top it up. Run engine without closing the radiator cap and top up the coolant level when it goes down. When level is stable, close radiator cap.
Aug 18, 2010 at 11:26 AM
