How to check a fuel pump on a 1995
1995 NISSAN PATHFINDER
AL REHM
I have a 95 pathfinder with 78000 mils on it 3.0 6 cylinder. It started and ran about 20 feet and then stop. It seems to be running out of fuel. i disconnected the fule line after the fuel filter uunder the hood and found no pressure. Is there a way to test the pump for operation while it is still in the vehicle or do I have to drop the gas tank? also does the fuel pump run on 12 volts or is it stepped down?
Jul 31, 2007 at 10:52 AM
[quote:aa2746c687="al rehm"]I have a 95 pathfinder with 78000 mils on it 3.0 6 cylinder. It started and ran about 20 feet and then stop. It seems to be running out of fuel. i disconnected the fule line after the fuel filter uunder the hood and found no pressure. Is there a way to test the pump for operation while it is still in the vehicle or do I have to drop the gas tank? also does the fuel pump run on 12 volts or is it stepped down?[/quote:aa2746c687]
Wire it direct from the battery ( you need a positive battery and ground lead )-find the fuel pump connector on the tank identify the wire color code, apply the jumper, No sound/buzzing-its gone-
Note: before the direct hook up -check for battery voltage on the fuel pump connector-no power there track it backwards could be a fuel pump relay-power present. could be ground problem-ground checks out
Pump is defective
Aug 2, 2007 at 5:08 PM
