2003 Nissan Pathfinder Maintenance interval
2003 NISSAN PATHFINDER
YIDAL8
Drive Train Axles Bearings problem
2003 Nissan Pathfinder 6 cyl All Wheel Drive Automatic
In owner manual maintenance section, there is no requirement to change fluids of the transfer case, or auto transmission. It says only to inspect.
Should I change fthese fluids? truck has 74,000mi.
Aug 11, 2009 at 8:10 PM
BLUELIGHTNIN6
  • 16,542 POSTS
transfer case fluid should be replaced every 30,000 miles. tranny fluid should only be inspected. only replace the tranny fluid if there are symptoms of a transmission issue.
Aug 11, 2009 at 8:15 PM
