2003 Nissan Pathfinder lOSS OF POWER
2003 NISSAN PATHFINDER
103,000 MILES • 6 CYL • 4WD • AUTOMATIC
DAVE GODSEY
Occasionally my daughter's Pathfinder can barely pull itself, even on a level street. If the engine is shut off for a few minutes, it runs fine. The dealer is unable to find any problem. Any ideas?
Jul 21, 2009 at 12:12 PM
Has the check engine light ever come on? Also, did the dealer check fuel pump pressure? And finally, has anyone checked to see if the catylatic converter is plugging? A clogged converter will cause a loss of power. Sometimes, at night they will get so hot, the will glow red hot. You may want to check that if it happens at night to you.
Jul 21, 2009 at 11:34 PM
