2001 nissan pathfinder v6 3.5
2001 NISSAN PATHFINDER
BODIE
4x4 with 101,000 miles on it. Heater works while idling Once moving about 4-5 miles it will blow cold air and shortly after temp gauge goes to hot. Radiator, thermostat, water control valve, and water pump have all been replaced. System has been pressure tested and bled. Still has same problem.
Jan 23, 2007 at 3:04 PM
[quote:dbfa3f99e4="Bodie"]4x4 with 101,000 miles on it. Heater works while idling Once moving about 4-5 miles it will blow cold air and shortly after temp gauge goes to hot. Radiator, thermostat, water control valve, and water pump have all been replaced. System has been pressure tested and bled. Still has same problem.[/quote:dbfa3f99e4]
Take the Stat back out-start it up run it for 10mins, hop inside do you feel more warm and cozy-if so change the Stat again might be Manu. defect.
Jan 24, 2007 at 8:25 PM
SERVICE WRITER
  • 9,123 POSTS
While it certainly is quite possible of a bad t-stat even though it's new, Try bleeding any air in the system again.
https://www.2carpros.com/forum/automotive_pictures/30961_nissa_1.jpg
Jan 24, 2007 at 8:41 PM
