fuel filter replacement
1999 NISSAN PATHFINDER
125,800 MILES • 6 CYL • 4WD • AUTOMATIC
66IMPALAD
where is the fuel filter located at on my truck
May 7, 2009 at 3:00 PM
Under the rear of the truck, above the rear axle, passenger side. Check out the images (below). Let us know how it goes
May 7, 2009 at 5:12 PM
OPSGUY21
where is the fuel filter for a 1999 pathfinder located
Oct 3, 2018 at 6:24 PM (Merged)
Under the hood on the passenger side. It's mounted on the front side of shock tower, in fuel line
TAMPICO
Sputter, not severly
Sometimes will sputter so bad it dies
New ,plugs,plug wires,dist. Cap,rotor,
Fuel filter,
Problem does not appear to be fuel deli
Very issue ,observe consistant fuel into
Trottle body
"brain" appears to be in working order
No visual defects(bured diods, relays)
Wires to "brain" arrear fine
Will start and idle cold or hot
Though still occationally sputter
Engine does smoke ,but not severly
Most of the time cant see any
Mar 30, 2019 at 7:52 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi TAMPICO,
Thank you for the donation.
Thee are various possibilities such as :
1. Throttle position sensor.
2. Air flow meter (AFM). Check if the sensor inside air flow is dirty. Use air flow spray cleaner to clean it. Be careful not to damage it with any physical contact.
3. Crank angle sensor.
4. Cylinder head temperature sensor.
Is the Check Engine Light showing?
Did you try to go into diagnostics.
UMUHEHE
Six cylinder two wheel drive Automatic 72,730 miles.
Could you please help me with the fuel filter location on the car? I have search for it but I was unable to locate it.
Thanks in anticipation.
Umuhehe
BLUELIGHTNIN6
  • 16,542 POSTS
The fuel filter is located under the vehicle near the fuel tank.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1778.jpg
DATNUMBA
i need to change fuel filter where is it located on the truck
KACEY
HI
It is located between the sapare wheel & the rear axle. you need to get under & see it will be mounted along the axle towards the spare wheel. (floor mounted spare wheel)
regards,
[quote:55a862964d="datnumba"]Transmission problem
2003 Nissan Pathfinder 6 cyl Four Wheel Drive Automatic 39,855 miles
i need to change fuel filter where is it located on the truck[/quote:55a862964d]
Mar 30, 2019 at 7:53 AM (Merged)
