1999 Nissan Pathfinder a belt sqreaches when cranked
1999 NISSAN PATHFINDER
208,000 MILES • 6 CYL • 4WD • AUTOMATIC
TBRANDT
During the past month (when the weather has gotten warmer), a belt in my engine makes a horrible sqreaching noise when I first crank the vehicle. The noise lasts for about 5 seconds or so. It only does this when it hasn't been running for several hours (like when I crank it first thing in the morning and when I get off of work).
Thank you for your help!
Tracy
May 26, 2009 at 9:24 AM
SCORPION73
Hi Tracy, I had this problem after my main belts had been replaced. It is an easy fix. But a little hard to get to. If you drop into your local mechanic, they can tighten the belts without much problem.
Jun 25, 2009 at 4:41 PM
