The fuel pump pressure should be 43 PSI.
Here is a guide to help you see how to do the job.
Position the ignition switch and the A/C system in the off position. Install a fuel pressure gauge in the the fuel line at the fuel filter connection. Locate and block off the fuel pressure regulator vacuum line. Confirm that no leaks are present, then start the engine. While the engine is at idle, visually verify the PSI reading on the gauge.
Please run down this guide and report back
Cheers
Mar 23, 2010 at 7:15 PM
