1996 Nissan Pathfinder Front driveshaft greasing
1996 NISSAN PATHFINDER
96PATHLE
Service Question
1996 Nissan Pathfinder 6 cyl Four Wheel Drive Automatic 109k miles
My '96 Pathfinder LE 4x4 needs the front drive shaft greased. The coupler on the end of my grease gun seems too large to be a snug fit to the small grease nipple on the drive shaft. Are there different grease nipple sizes for different vehicle parts? I was under the impression that these are a standard size...
Oct 18, 2010 at 8:34 AM
SERVICE WRITER
  • 9,123 POSTS
No, there are different sizes and styles. There are different attachments/adapters that can be used to adapter yours to it. You can also replace the fittings.
Generally most are the same but there are a few rebels to the group.
Oct 20, 2010 at 5:10 PM
96PATHLE
Problem is, all I have been able to find online is needle adapters and rubber adapters for my grease gun. No sign of any varying size adapters for different sizes of nipple. If you can suggest a link I'd appreciate it!
Oct 21, 2010 at 10:32 AM
SERVICE WRITER
  • 9,123 POSTS
You may to contact the manufacturer to verify they will work or to see if they can provide the one you need.
http://www.buy.com/retail/product.asp?sku=212938934&listingid=57411082&&
Oct 21, 2010 at 11:14 AM
96PATHLE
Turns out the issue was the difficulty in accessing the grease nipple. I obtained a flexible hose adapter for the gun and the fit was fine. The nipple "looks" small compared to the gun's fitting but it's the only one on the car so there's no basis for comparison.
Thank you for your responses!
Oct 25, 2010 at 8:37 AM
