I have a 1996 Nissan Pathfinder that I have recently had quite a bit of trouble with. The problem is that the vehicle will shut off while I am driving, but will always restart after the vehicle has come to a stop. The vehicle has had a number of problems recently that has caused me to replace the fuel pump, ECU and crank shaft position sensor. I replaced the ECU because I had determined that the fuel injectors were not receiving a signal to deliver fuel. After replacing the ECU and repositioning the distributor/camshaft position sensor (which the mechanic reinstalled incorrectly) the vehicle ran perfectly for about a week. Then the vehicle began to cut out while running again. As a result I removed the upper intake manifold and measured the resistance of all 6 fuel injectors and they were all within the range specified in the repair manual. To recap, the injectors are not receiving a signal to fire. The ECU has been replaced and worked fine for about a week. The crank shaft position sensor has been replace, the fuel injectors have the correct resistance, the distributor/camshaft position sensor works correctly which was tested by replacement, and the computer is not showing any codes. I am really out of ideas here so any help would be much appreciated. Thanks
Nov 23, 2009 at 12:11 PM
