1996 Nissan Pathfinder
1996 NISSAN PATHFINDER
14,500 MILES • 6 CYL • 4WD • AUTOMATIC
ONEIL96
my nissan pathfinder rocks side to side on freeway it feals like its going to tip over
Feb 19, 2008 at 6:42 PM
MASTERTECHTIM
  • 4,750 POSTS
i have seen this before. it is caused by the bushings on the rear end radius arms. these are the arms that keep the rear end from moving forward and back. if you look closely at the bushings you will see they are probably worn out.
Feb 19, 2008 at 6:55 PM
MASTERTECHTIM
  • 4,750 POSTS
i assume the tire pressures are correct.
