1995 Nissan Pathfinder Valve lifters, rod-bearings, push-ro
1995 NISSAN PATHFINDER
190,000 MILES • 6 CYL • 4WD • AUTOMATIC
RION95
I have a few repetitive tickings in the engine block. Should I adjust the valve lifters?
Sincerely,
Self-made Home-mechanic getting in to trouble.
[img:3ddef91c3b]http://www.2carpros.com/forum/automotive_pictures/485267_White_truck_zinfin_1.jpg[/img:3ddef91c3b]
Feb 18, 2010 at 2:53 PM
2CARPRO JACK
  • 11,533 POSTS
Those are hydraulic lifters and dont require adjusyment.If you have a valve ticking (fast tick) then you most likely have a lifter that has gone away.Do you have any oil pressure issues? like warning lights or generally low pressure on the gauge (if equipped). If not then it may just be a lifter gone bad, it happens.
Feb 18, 2010 at 10:34 PM
