having a problem starting car andwas wondering if it could be the brake switch or something else
Feb 9, 2010 at 5:26 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
no, brake switch just operate the brake lights. is vehicle starting or not starting at all?
Feb 25, 2010 at 5:11 PM
MADDOG45
MEMBER
sometimes it does and sometimes it dosnt and i dont know why exactly
Feb 26, 2010 at 12:34 AM
MADDOG45
MEMBER
i also thought it might be the gear sifht switch because sometimes it hesitates when putting it in gear like drive,or reverse
Feb 26, 2010 at 12:37 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
try starting it in Neutral, if it starts then neutral safety switch is OK.
Feb 26, 2010 at 11:52 AM
MADDOG45
MEMBER
i tried that sometimes it starts and sometimes it dos'nt
Feb 26, 2010 at 12:19 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
when you say sometimes it doesnt start, what does it do exactly? does it just crank over and over or does it not crank at all? is the check engine light on when driving it?
Feb 26, 2010 at 12:31 PM
MADDOG45
MEMBER
sometimes it will not crank at all u turn the key and nothing happens like theres no power going to the starter motor and today for the first time the check engine light came on for like two minutes and then went off although the starting problem as stopped for the time being
Feb 26, 2010 at 5:15 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
ok if its not cranking at all sometimes then this could be a failing starter or a failling ignition switch. i suggest having the starter motor tested and if tests OK suspect faulty ignition switch or wiring to switch
