1994 Nissan Pathfinder How to replace right front outer tie
1994 NISSAN PATHFINDER
205,000 MILES • 6 CYL • 4WD • AUTOMATIC
DALE SMYTH
Took vehicle in for alignment and they were unable to do it saying the right front outer tie rod with sleeve needed to be replaced first. I am not a trained mechanic but do a lot of small things myself. Is this a job best left to a professional or can a reasonably adept amateur handle it?
Apr 28, 2009 at 5:14 PM
KHLOW2008
  • 41,814 POSTS
Hi Dale Smyth,
Thank you for the donation.
Replacement of the tie-rod end is rather straight forward but you would need a ball joint remover to disconnect it from the knuckle.
Mark the initial position of the tie-rod end lock nut by counting the number of threads left and when installing, get it seated as close to original position as possible.
Apr 29, 2009 at 1:09 PM
