1994 Nissan Pathfinder CUTS OUT AT 65
1994 NISSAN PATHFINDER
10,000 MILES • 6 CYL • 4WD • MANUAL
SWEETTOOTH1970
I have a 94 pathfinder and it cuts out and shuts off at 65mph. It has a slight smoke and smell coming from exhaust. Any ideas?
Jul 29, 2009 at 8:06 PM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Jul 29, 2009 at 8:10 PM
