I would of liked to have had the mileage of the car and repair history. I will try to asnwer the question the best that I can. The distributor is driven by one of the following things; I am not familiar with your vehicle so I am making a guess here, It is either driven by the cam shaft the oil pump, or the timing belt. If there is nothing physically wrong with the distributor I am going to guess that the distributor is run by the cam shaft. The cam shaft is also driven by the timing belt, which means the timing belt could have broke and the reason you can't turn the rotor is the springs from the valve are locking the cam shaft in place. You don't have the physical strenghth to turn the rotor and overcome the pressure of the springs. Good Luck :)
Dec 8, 2006 at 2:35 PM
