I have a 1995 Infiniti G 20 with a 2.0 liter engine (same as Nissan) double over-head cam. I check all the basics like : spark plugs and wires, vacuum leaks, mass airflow sensor, ground, I changed the distributor cap and rotor, I checked the fuel pump pressure and volume.
The problem is this: the car seems like its running only on 2 cylinders. It stumbles and back-fires. I removed all 4 four spark plugs and it seems to me that the plugs are not firing properly.
Can someone give me some trouble-shooting info so that I can see if my distributor is bad. I would really appreciate it very much. Thank you.
Jun 1, 2006 at 9:53 PM
